Are ported heads worth the money?
Originally Posted by slamedboosted&shaved
i have a 5.3l whippled, z06 cam, Lt's, ory pipe, and i was thinking about getting a set of heads, which stage and what kind of gain can i expect.
thanks
thanks
let us know what you decide to go with
Here's a link to a recent thread by BBT with some dyno graphs of his gains from some mild Stage I WCCH heads...seems worth it to me
https://www.performancetrucks.net/fo...d.php?t=356706
Originally Posted by Nasty N8
Definaly power is in the heads. A Stage 1 would be plenty for your setup but they would need to be specificly for boost for the best application.
Nate
Nate
Look for heads with emphasis on exhaust work and smoothed combustion chambers. Avoid shaved deck heads or ones that increase compression ratio, could cause detonation and KR. Stage 1 should do nicely. You could also look for some stock #317 - LQ9 heads, they have a larger combustion chamber, bigger intake valve, and "D" shaped exhaust port that will flow much better. They also bolt right up and have the exact same mounting pattern so the blower will slip right in. You can find them fairly cheap if you look around here or eBay ( about $200-300 if someone needs the cash ). My two cents....
sauldgold
Jul 23, 2015 02:15 PM
