Poor idle at start up... Any ideas?
Old Oct 4, 2004 | 10:13 PM
computernerd's Avatar
Default Poor idle at start up... Any ideas?
I just got a 2000 Tahoe about two weeks ago.
It's bone stock right down to the air filter.
It has 5.3L and only 46k miles on it.
My problem is: at startup it has a poor idle.
It only idles at 500rpm to begin with and the the poor idle it drops to 200rpm then catches itself and revs to 800rpm.
The problem seems to happen more at start up, but I have also noticed it at a red light.
I'm going to check the fuel filter this weekend. Any other ideas?
Old Oct 4, 2004 | 10:31 PM
marc_w's Avatar
My first guess would be the throttle body... I'd probably pull it off and clean it out nice and good.
My truck does that when something is up with my IAC motor due to some poor tuning by me. I have a feeling your TB might be gunked up with carbon or other junk.
Old Oct 4, 2004 | 11:08 PM
BlownChevy's Avatar
blownerator
25 Year Member
Good advise...start with the TB and IAC valve.
Old Oct 5, 2004 | 09:42 AM
budhayes3's Avatar
PT's Slowest Truck
Check the fuel pressure regulator also if you're experiencing this more after a hot soak. Pull the vacuum hose off of it and see if fuel is present, if so, it's ng.
Old Oct 5, 2004 | 09:58 AM
Thanks for the input.
I will check the throttle body and the fpr.
Seems to happen in some for all the time, so I'm banking on it being the throttle body.
ARC
57
Feb 21, 2022 10:54 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
The_W
Aug 15, 2015 08:07 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
