View Poll Results: What will my rwhp be after my new motor?
Voters: 26. You may not vote on this poll
Poll: RWHP with new motor?
14 Second Truck Club
What do you think my rwhp will be with my new motor?
Motor:
-1998 5.7 LS1
-FMS 224/224-.588/.588-112
-PP Stage 2 5.3 Heads milled .010"
-FMS Dyno-Tune
-Speed Pro Stock Replacement Pistons & Rings
-ARP Pro Series Rod Bolts
-GM Performance Lifters
-Durabond Cam Bearings
-Clevite 77 Rod Bearings
-Polished Crank
-Honed & Crosshatched Cylinders
-FMS Pushrods
-FMS Ported Oil Pump
-160* Thermostat
-New Gaskets & Seals
Bolt-on's
K&N FIPK
Descreened MAF
FMS Ported Throttle Body
Electric Fans
ASP Crank Pulley
Taylor Plug Wires/TR55 Plugs
LaPole Mid-Length Headers
Cut-Outs
8.1 Injectors
All I have left to do is get the cam, machine work, heads and bigger injectors. Then drive down to Futral and get it tuned. I'm gonna go ahead and get the cam and the patriot dual spring kit within the next few weeks. I'll get the rest when I get my taxes back.
Motor:
-1998 5.7 LS1
-FMS Dyno-Tune
-Polished Crank
-FMS Pushrods
-160* Thermostat
Bolt-on's
K&N FIPK
Descreened MAF
Electric Fans
ASP Crank Pulley
Cut-Outs
8.1 Injectors
Voted for the 360 I put down close to 330 with a 5.3 and a slightly smaller cam true duals and dynatechs so you should have close to 360 IMO. Put some juice on it too for good measure
ttt....
I just seen Scream's dyno with his bolt-on LS1 w/ a 224/224-112 and STOCK heads and NO dyno-tuning and he put down 354rwhp/357rwtq. Oh yeah, that was also with the truck intake, which I plan on using as well. Seeing good numbers like that with no heads or tuning gets me pumped up on the potential of this LS1 build-up!
