View Poll Results: Predict my rwhp horsepower
Voters: 12. You may not vote on this poll
Poll: Predict my horsepower
14 Second Truck Club
I'm taking the parts to the machine shop tomorrow to get everything put together, balanced, etc. Then a FLT stage 4 4L60E and everything will be swapped over.
Here is the set-up:
-383 LS1 block bored to 3.903"
-Eagle 4.000" Crank
-Scat 6.125" H-Beams
-Mahle Forged Pistons
-Patriot Stage II 5.3 Heads
-F13 (230/232-.595/.585-114+4)
-Stock Truck Intake (Just for now)
-44lb Injectors
-Full Bolt-ons
-Dyno-tune by FMS
-Cut-outs
I know I should be in the low 400rwhp range. I think the compression should be around 10.8-11.1:1. After my taxes next year, I plan on getting a FAST 90mm intake/tb set-up. Allan Futral said this would bump my top-end up without affecting low-end on the 383. Just trying to get a good idea would the truck intake will make for the time being...
Here is the set-up:
-Eagle 4.000" Crank
-44lb Injectors
-Full Bolt-ons
-Dyno-tune by FMS
-Cut-outs
Your power with the truck intake is going to flatline at about 5200-5500 rpms and stay there. It will run out of air with that setup. Kano picked up about 4-5 tenths just from going from a truck intake to a LS6 intake, so the 90/90 setup should work great.
whitelazer
Sep 22, 2015 09:38 PM
