View Poll Results: 50/50 Coolant/Water Mix or 100% Coolant
50/50 coolant/water mix
33
97.06%
Coolant Only
2.94%
Voters: 34. You may not vote on this poll
Poll: 50/50 Coolant/Water Mix or 100% Coolant
Old Oct 15, 2007 | 06:50 PM
I run 50/50 and have never had a cooling problem.
Old Oct 15, 2007 | 08:27 PM
Stoichiometric's Avatar
For best heat transfer water+ redline water wetter works good, I use that in my dirtbikes where anti-freeze protection is not of importance. Otherwise at least 25-30% dexcool + water. The more anti-freeze you add the less heat transfer ability you have. All has pretty much been said above.
Old Oct 16, 2007 | 02:45 AM
14 Second Truck Club
I wonder if this has anything to do with why my truck dynoed like 15 more rwhp after letting it cool down for 20 min.?
Old Oct 16, 2007 | 12:04 PM
2001si3rr@'s Avatar
I just did a water pump on my 2001 Silvy, buy either the pre mixed AF or buy pure AF and distilled water and mix yourself.
Old Oct 16, 2007 | 01:17 PM
silver-mod-o's Avatar
Hunt&Fisherator
I used to run straight water wetter in mine... I have switched to 50/50 mix with distilled water but it ran cooler with the water wetter straight...
Old Sep 26, 2009 | 08:03 PM
custm2500's Avatar
Ph.D. in HUBRIS
Running 100% coolant is a HORIBLE idea!
Water cools much more efficantly and 100% is best for everything but two reasons. One it freezes. Secondly it will rust your motor and currode everything. Enough ANTI-FREEZE(the real name, it isn't coolant) to keep it from freezing is your best setup for coolest performance.
The reason 50/50 is most common is because it covers those properties. Currosion resistance, freeze protection, yet plenty of water for enough cooling.
Old Sep 26, 2009 | 08:09 PM
BlackGMC's Avatar
Resident Retard
HOLY OLD THREAD Batman!
Old Sep 26, 2009 | 08:15 PM
00ChevyScott's Avatar
Wearin' da big hat
What about 100% urine?
Old Sep 26, 2009 | 08:22 PM
BlackGMC's Avatar
Resident Retard
lol....
A long time ago when i used to work in Dallas, my mustang overheated in traffic and I was late to work so I had about 10 half empty Dr. Pegger bottles floating around in my car, soooooooooooooooooooooooooooooo, i poured all of them in the radiator.... Needless to say i ended buying a new radiator, heater core and replacing all the hoses shortly after that... The smell was unbearable...
Old Sep 26, 2009 | 08:26 PM
Wearin' da big hat
lmao, the antifreeze you can drink!
