Polished my valve covers, coil brackets?
Old Nov 29, 2007 | 02:52 PM
Tootall's Avatar
Originally Posted by Raffman
OK here's the pic with the TB that's still in process. Anyone wanting to do this I'll tell ya up front it's a bitch. Unless your set up to sand and polish allready the cost would be too much. One tip though is to get a B&D detail sander called the mouse with all the attachments, its a labor saver.
so did you use any jeweler's rouge or anything?
Old Nov 29, 2007 | 05:18 PM
Raffman's Avatar
No, jewlers rouge is for gold and silver, not very aggressive. The trick is to sand ,sand and more sand. Start with the finest grit you can but in the case of these v/c they are rough so I actually started with 80 grit then move up the grits to 120, 220,320,400, 600, then 1000 and even 1500. then comes compound, first tripili with a ragwheel, then white with a cotton buff. To keep from wearing grooves in the soft aluminum always work across the previous strokes in right angles or "x" pattern just like body work.Use round rolls for rounded surfaces and a rubber block or flat sander (jitterbug or mouse) for the flatter areas. The shinner the work gets the dirtier you get but a little work here and there and you'll have a nice piece.
Old Dec 2, 2007 | 08:00 PM
03chevy5.3rcsb's Avatar
looks good, but the shitty thing is that they'll be nasty in a month under the coil brackets
Old Dec 2, 2007 | 11:04 PM
RedHot04's Avatar
why the hell is it we can't buy a nice set of fab. aluminum or even chrome covers for the Vortec without spending nearly a paycheck? Is it really that hard to manufacture a center bolt version that makes it so cost prohibitive? Or is it just that there isn't enough demand? I just don't get it. If they can make adapters for older style retrofits they can make covers REASONABLY priced. What about chrome dipping them, anyone done that?
Sorry to get too far off topic...
Old Jan 21, 2008 | 12:14 PM
Superado's Avatar
11 Second Truck Club
gonna look into powder coating a set...then maybe chrome plating the coil brackets...
cuz the vc's aren't the only thing that are high dollar...
have you priced the relocation brackets?
Old Jan 21, 2008 | 12:25 PM
Mangled03gmc's Avatar
Baltimore Whore
Looks good man, thats alot of work. I was getting frustrated when I was just sanding, smoothing mine to paint. Are you thinking about having them powder coated clear or spraying clear on them so they don't get dull..
John
Old Jan 22, 2008 | 10:06 PM
GMC_DUDE's Avatar
don't bother with painting the block, the only time that you'll see the paint is when it's on the stand or when you're changing the oil. It's not worth the prep time, cost of paint, and the disappointment of your wasted time and money.
Painted my entire 4.8 "Chevy Orange". Once installed, you couldn't see hardly any of it because the engine sits so low and is covered with accessories. For my 6.0 I didn't bother. Planning instead to get or make some coil covers this summer. Can post some pics of the 4.8 if you like (or I could even sell it to you cheap ).
The_W
Oct 28, 2015 09:00 PM
BlackGMC
Aug 17, 2015 07:07 PM
jroctpb
Aug 11, 2015 03:52 PM
low2001gmc
Jul 21, 2015 02:09 PM
