po315 code?
Old Nov 5, 2005 | 01:19 PM
98TAauto's Avatar
Default po315 code?
i guess this can go here.. im just looking for a quick answer on what that code is for? Its gonan be misfires? but it doesnt list a 315 code on my book?
I have the nelson tune also and I woulda thought those codes were edited?
any ideas?
Old Nov 5, 2005 | 02:34 PM
budhayes3's Avatar
PT's Slowest Truck
P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory
Gotta get the crank relearn done and you should be good to go
Old Nov 5, 2005 | 05:59 PM
98TAauto's Avatar
bud, where/how do I go about that?
I take the truck will be fine, just have a SES light untill i get that fixed?
Old Nov 5, 2005 | 07:38 PM
budhayes3's Avatar
PT's Slowest Truck
If it's running OK you'll be fine...when the crank variation is waaay off it may run poorly (this happened to me once). But usually it'll just throw a code. The crank relearn needs to be done with a TechII or other capable scan tool. Certain tuning software can do it also (I think LS1Edit, EFILive, etc). Last time I needed it done I just went to the dealer and shelled out $40 bucks for them to do it and clear the code...it takes them about 5 minutes. They basically follow the prompts on the scan tool and bounce the engine off the rev limiter for a second until the PCM learns the crank angle variation. Just make sure that if you have it done at a dealership that you tell them not to reflash your PCM or you'll lose your custom tune...tell them that you just want the crank relearn done and the code cleared.
Old Nov 5, 2005 | 08:03 PM
98TAauto's Avatar
i think the guy welding my y pipe tomorrow has tech2 so hopefully I can get it done then
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
