PLz Help, Cam installed, new ticking noise
I ran some B12 chemtool through the crank case and then changed the oil. I put 5 quarts oil and 1 quart Lucas oil stabilizer in, and no more tick. I will check the oil pump out in the next couple of days. No change in oil pressure though.
I pulled everything apart and the o-ring is NOT cracked or cut. It was a little loose on the pickup tube. What should I do? I'm going to put a new one on, so hopefully it will fix the problem.
Oh yeah, the oil pump is a stock ls6 oil pump, part# 12586665. What should the oil pressure be with this pump?
lxcoupe
Jul 27, 2015 08:19 PM
all_individual
Jul 13, 2015 11:01 AM
