PLz Help, Cam installed, new ticking noise
Old Aug 7, 2005 | 11:37 PM
chevyerett's Avatar
I ran some B12 chemtool through the crank case and then changed the oil. I put 5 quarts oil and 1 quart Lucas oil stabilizer in, and no more tick. I will check the oil pump out in the next couple of days. No change in oil pressure though.
Old Aug 9, 2005 | 11:29 PM
chevyerett's Avatar
I pulled everything apart and the o-ring is NOT cracked or cut. It was a little loose on the pickup tube. What should I do? I'm going to put a new one on, so hopefully it will fix the problem.
Oh yeah, the oil pump is a stock ls6 oil pump, part# 12586665. What should the oil pressure be with this pump?
all_individual
Oct 10, 2015 10:09 PM
lxcoupe
Jul 27, 2015 08:19 PM
chvy=power
Jul 27, 2015 10:06 AM
all_individual
Jul 13, 2015 11:01 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
