Plug Wires with Dynatechs
Old Jul 27, 2006 | 10:55 AM
Dub Silverado's Avatar
Default Plug Wires with Dynatechs
Is there a particular brand of wires you guys are using with dynatechs? Is there any problem with stockers not fitting with them?
Just trying to line everything up before the install.
Old Jul 27, 2006 | 10:58 AM
Dark Halo's Avatar
I use MSD's with my pasesetter's and they are fine. Im not sure about the stock one's though because of the heat sheilds that are on them.
Old Jul 27, 2006 | 11:00 AM
Ive had a set of MSD on my old truck and they were fine. Ive also heard alot of good of the Granatelli wires but they are more than twice the money.
Old Jul 27, 2006 | 11:01 AM
silver-mod-o's Avatar
Hunt&Fisherator
I have ALWAYS had good luck out of Taylor thundervolts.. I had a set of 8.2's on mine with pacesetters and will be getting another set of the same ones here very shortly.
Old Jul 27, 2006 | 12:08 PM
02BlueStepside's Avatar
My stock wires were fine with the dynatechs. When I switched to the Taylor 409 wires though, they are a little longer and make it diffecult to clear the primary of the dynatechs. You have to go around them instead of between the headers and the block.
Old Jul 27, 2006 | 01:38 PM
jjpea's Avatar
I'm using the stock wires, truck started hesitating a little, troubleshot it at night to make things easy, i was expecting to find a bad wire and sparks shooting off the wire, but the wire on #7 had just about fallen off, i think that was because i pulled a little to hard on it when i put the headers on it and the spring fell out of the wire plug. good luck
Tydriver
45
Oct 23, 2015 09:19 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Silver8ado
Sep 14, 2015 06:35 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
