plug n play intank fuel pump part #
Old Apr 15, 2007 | 11:19 PM
405hpta's Avatar
Banned
Default plug n play intank fuel pump part #
I've searched and found a few different #'s....looking for the Walbro 255 part number that is the direct bolt in for the truck. There are a few on ebay pretty cheap.
Old Apr 16, 2007 | 12:46 AM
Lurius's Avatar
I read an article recently about counterfeit walbros showing up on ebay. Even with stamps.
I ordered mine from a sponsor, it was the fbody kit. It came with a
section of hose, some wiring pieces(I just used crimps as the connections werent the same), and hose clamps. Once you get into the pump assembly its fairly easy to see how to do it.
-Lurius
PS: The hose that was included with mine though was not submersible, and it deteriorated in 3 days, and the hose blew.. so I had to order some expensive *** r10 hose from oreilly's for 20$ a foot, used about 8 inches. Might want to do this anyways, or risk having to do it over again, gah.
Old Apr 16, 2007 | 10:04 AM
02BlueStepside's Avatar
There isn't a direct bolt in fuel pump for the trucks. All have to be modified a little. I am using a Holley pump (made by walbro) that is actually made for mustangs.
Old Apr 16, 2007 | 09:27 PM
405hpta's Avatar
Banned
what kind of "changes" were required to make your's fit 02Blue?
Old Apr 17, 2007 | 07:30 AM
Here is the writeup I used for the holley pump
https://www.performancetrucks.net/fo...y+pump+install
A lot of people now are cutting the bottom of the bucket up in order to get a little more fuel flow. Here is the writeup for that.
https://www.performancetrucks.net/fo...l+pump+install
Old Apr 17, 2007 | 04:09 PM
Allgonoshow's Avatar
i beleive you can buy a direct fit pump from Magnason
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
