Please help me trying to swap a 2014 engine on my 2007 nnbs
Old Feb 24, 2017 | 10:46 AM
Jaygeer28's Avatar
Registered User
Default Please help me trying to swap a 2014 engine on my 2007 nnbs
Does anybody know what will i need to mod please need help thanks in advance
Old Feb 24, 2017 | 10:52 AM
FFDP's Avatar
Just spit balling some parts here but I'm pretty sure you are going to need the motor/transmission, wire harness, computer, upgrade your fuel system for enough fuel flow for the DI motor, motor mounts.
Custom tuning and figure out a way to make the gauges work. The ECO Tech 3 Controllers never had a 4L60e transmission so that's why I said transmission as well.
Old Feb 24, 2017 | 10:58 AM
Jaygeer28's Avatar
Registered User
Thanks, i have motor trans cats driveshaft and wiring harness do you know where i can get the ecu from?
Old Feb 24, 2017 | 11:01 AM
FFDP's Avatar
Junkyard/wrecker or you may have to contact a dealership and see if you can buy one new. Not sure if you need an exact VIN number though to match the motor/trans combo or if there is another way to know what you want.
Old Feb 24, 2017 | 11:12 AM
Slow05CC's Avatar
Avery@texas-speed.com
I believe the gen 5 has electric power steering. Might want to look into that!
You may be able to get a computer from the following places: GM, Speartech, or PSI. Speartech may be your best option at this moment, I would recommend calling them and seeing if they have any info regarding the harness and computer.
Old Feb 24, 2017 | 11:22 AM
Jaygeer28's Avatar
Registered User
Would it be better if i sell motor and get a 2013?
Old Feb 24, 2017 | 11:34 AM
FFDP's Avatar
If you wanted probably an easier swap, yes it would be better to find a GEN 4 engine.
