Piston Slap - Are the 2003s better???
Old Dec 2, 2002 | 08:34 PM
Alex D's Avatar
Default Piston Slap - Are the 2003s better???
I was just wondering about the dreaded piston slap issue. There is much out on the forum on this issue and I did a search.
A couple of things I did notice: The TSB posted in one of the threads as to the affected engines, is only listing the regular fuel version of the 5.3, bit not the FlexFuel (85% Ethanol compatible) version of the 5.3 (VIN code Z). Is the Flex Fuel version better/different??
Second, are the 2003 truck/SUV engines any better??
I have a 2002 Suburban Z71 and my wife has a 2001 Trans Am......the Burb is quiet, but only has 2,900 miles on it.....the T/A has about 13,000 miles on it and a little piston slap but not bad at all and it is not getting worse......
Old Dec 4, 2002 | 10:02 AM
Alex D's Avatar
Default Re: Piston Slap - Are the 2003s better???
Hmmmmmmm, no responses....seems the piston slap in no longer a problem for GM..... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 10, 2003 | 10:09 PM
SkagSig40's Avatar
No the 2003's slap like a deisel! GM has not fixed this problem yet! My dealer is going to try to fix my 2002 Camaro LS1 piston slap with a rebuild.
Old Aug 11, 2003 | 12:19 AM
FILE's Avatar
Are you sure it's piston slap? I thought I had piston slap on my 01 and found I did not. I had more of a moisy lifter or something. I heard piston slap on an 00 Chevy and boy was it loud. Mine was just a slight tapping noise. This truck with piston knock was a loud metal to metal bell sounding noise. Just terrible in my opinion. On my 02 I do hear engine noise but it's even quaeter than 01. If you want to read more about this issue you might want check this site out.
http://www.pistonslap.com/
Old Aug 11, 2003 | 02:58 AM
Tokez420's Avatar
i thought the 03 pistons and cylinder walls were coated with teflon to fix the noise?
i have had piston slap on my 02 since about 7K i have 41K and getting worse. i bitch many times, always said it was normal
Old Aug 11, 2003 | 11:43 AM
SkagSig40's Avatar
I have seen the Pistonslap.com web site and the sound clip sounds just like my Camaro does. I pray My 2003 Silverado does not ever do it but some times I can hear a very quiet rapid knock when I slow down for a stop.
Old Aug 11, 2003 | 04:52 PM
2003, and I haven't noticed anything, and I am a little **** about stuff with my vehicles.
Old Aug 11, 2003 | 07:09 PM
GREGGO's Avatar
Niether one of my engines made noise.....well until I blew a hole in the piston on the first one it didn't.
Old Aug 12, 2003 | 07:41 PM
EVIL's Avatar
11 Second Club
i just joined the slap forum, i hope my 2003 doesnt have any problems like that!!!!
at what mileage are you guys changing your oil for the 1st time. hardtop and i were talking about this the other night since he just got a gmc 5.3. he said he was going to wait till 5000 miles to do the 1st change. i have about 1800 on mine now....what to do?
Old Aug 12, 2003 | 07:55 PM
Hardtop's Avatar
My truck only has 750 miles so far and no slap yet. When does it usually start? Evil and I have talked about the first oil change mileage. A couple of people whoose opinion I respect said keep the oil that it came with for 4000 miles. I'm going to do that and add if necessary. So far it hasn't used a drop. Did the same thing with my wifes 03 Infiniti G35. Changed at 4000 miles for the first time and it only used about 1/8 a quart. Hasn't used any since. Will be going to Mobil 1 when I change it.
Bruce
