piston offset question engine building advice please
Old Jul 3, 2011 | 03:09 PM
06chevy5.3's Avatar
Default piston offset question engine building advice please
so here it goes I have a set of foreged wiseco pistons that i sent to the machine shop to be balanced when i got them back he put them in a box with numbers indicating which piston is which number.... I think??? but shouldn't all the pistons weigh the same if its balanced and not matter which piston goes where???
So i went to assemble the engine yesterday Wiesco being offset pistons have a dimple thats supposd to face the front of the engine well 4 of them are wrong if i install the pistons in the cylinder number indicated on the box cylinders 5,6,7,8 the dimple faces the rear. but the valve reliefs line up
So should i just ignore the numbers on the box and install them according to the dimples or send them back to be rebalanced?????
Old Jul 3, 2011 | 03:25 PM
Swerve7rpm2000's Avatar
put all dimples towards the front of the motor, and do use the numbers, intake and exhaust valve reliefs should be on opposite sides i belive :]
Old Jul 3, 2011 | 04:09 PM
06chevy5.3's Avatar
yah i fugerd they should all weigh the same if he balanced them maybe he gave me a box with writing from another job
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 14, 2015 10:28 PM
Austino
Jul 30, 2015 03:28 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
