piston
Old Jul 21, 2023 | 12:03 PM
turboal1's Avatar
Default piston
Help. I have a 6.2 L9H, does it have valve notches in the pistons or is it a flat top ?
has anyone put a 220 dur- .600+ lift cam in a stock motor
Old Jul 21, 2023 | 10:13 PM
RDF1's Avatar
DuNnO
5 Year Member
L9H had VVT which should have Valve Relief but if your wanting to put a 220 duration cam in a 6.2 that is a very small camshaft for that.
Old Jul 26, 2023 | 02:34 PM
turboal1's Avatar
how big do you think i can go without hitting the valves ? i want to put a set of 1.8 roller rockers on,
to increase the lift, my cam is a Comp VVT 210/224 556/568 114-LSA 1500-6600rpm i have a small 2500 stall
Old Jul 26, 2023 | 03:14 PM
RDF1's Avatar
DuNnO
5 Year Member
I've ran 232/244 .621/.604 112.5+3 in LS3 with stock pistons no problem.
your only issue is going to be the tight torque converter.
Could get away with this cam with that converter.
https://cammotion.com/camshafts/tita...217-225-114-2/
stroker87
Apr 8, 2020 08:16 AM
jfuegner
Mar 16, 2020 09:51 PM
turboal1
Jul 7, 2018 08:06 PM
turboal1
Feb 21, 2018 01:02 PM
bluebommer07
Aug 3, 2017 11:18 PM
