PCV question
Old Jan 25, 2007 | 02:07 PM
  #31
thunder550's Avatar
High on diesel fumes
I'm going to check valve seals next and run a compression test. Also need to pull the plugs out and see what they look like.
Old Jan 25, 2007 | 03:12 PM
  #32
dewmanshu's Avatar
Moderately Differentiated
i lost 3 exhaust valve seals on some More Performance heads...there is no doubt in your mind it is a problem...at idle the smoke is pouring out of the exhaust. You are losing alot of oil IMO, I just can't imgaine it coming from bad valve seals. I only would lose a quart every 2500 miles.
Old Jan 25, 2007 | 03:24 PM
  #33
thunder550's Avatar
Well I think I only have a few possibilities left.
First, could have been a combination of leaking intake rocker bolts and PCV, but I don't think so. It's not smoking any less now, and it wasn't smoking any less when I removed the PCV lines.
Second, could be bad ring seat. Compression/leakdown test will tell me.
Third, could be bad valve seals.
Fourth, could be improperly sealed head gaskets. Compression/leakdown test will tell me this also.
Fifth, could be cracked head. I have not heard of any problems with TSP's CNC program on GM castings, so I doubt this. I did see a lot of issues with oil burning when they were using the Dart castings, but that was almost a year ago and they have since stopped using Dart.
I can't think of any other way that oil could be getting into the cylinders.
Old Jan 25, 2007 | 03:49 PM
  #34
dewmanshu's Avatar
fww...mine WAS the exhaust valves, so smoking would be worse I guess for me. Well get to these tests!!!!
Old Jan 26, 2007 | 10:41 AM
  #35
blown3qtr's Avatar
Good luck Bro. I bught the TSP 6.0 stage 3 heads so I'm hoping it's not your heads.
Old Jan 26, 2007 | 11:41 AM
  #36
vanillagorilla's Avatar
I vote for a ring seating issue, but only because you're down on power. What were your rings gapped at? What kind of rings did you use? Maybe try a thicker oil and see what happens for a temporary fix.
Old Jan 26, 2007 | 01:32 PM
  #37
thunder550's Avatar
I'm not sure what the gap was, but I think maybe .002? Does that sound about right? Gapless stainless top ring, ductile iron second. I'm already using VR1 20w50 oil...what would you recommend?
Old Jan 27, 2007 | 04:16 PM
  #38
budhayes3's Avatar
PT's Slowest Truck
Have you done a compression and leak down test yet? Hoping that you end up with an easy fix, I hate it when someone puts alot of blood, sweat, and dough into a project just to have to re-do it
Old Jan 29, 2007 | 10:00 AM
  #39
thunder550's Avatar
No I was really busy with other stuff this weekend, and this week doesn't look much better....as of right now the only time I have free this week is Friday afternoon.
I was thinking though - even if it does turn out to be a ring seating problem, it will give me a good excuse to go with a smaller dish piston and bring my CR back up. Trying to look on the bright side.....
Old Jan 29, 2007 | 08:33 PM
  #40
thunder550's Avatar
Did a compression test tonight....new thread here
https://www.performancetrucks.net/fo...14#post3548414
lucas287
31
Jan 12, 2021 06:18 AM
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
