PCV question
Old Jan 24, 2007 | 03:35 PM
  #21
thunder550's Avatar
High on diesel fumes
I had Jon at TSP check with his techs, and they told me to make sure to seal up the intake rocker bolts with black silicone, which I didn't do. I'll try that next and see what happens.
Old Jan 24, 2007 | 03:41 PM
  #22
budhayes3's Avatar
PT's Slowest Truck
It would be cool if that's the problem!
Old Jan 24, 2007 | 03:47 PM
  #23
Tootall's Avatar
ok found what I was looking for, but doesn't sound like anything similar to what you're dealing with
https://www.performancetrucks.net/fo...d.php?t=379485
Old Jan 24, 2007 | 04:05 PM
  #24
thunder550's Avatar
Believe me, I'm hoping that's it too! I'm feeling a little bit of optimism again.
Tootall - thanks for checking that out. Definitely not anything that I'm dealing with, but it's good to know anyway.
Old Jan 24, 2007 | 05:17 PM
  #25
thunder550's Avatar
Post #7
https://ls1tech.com/forums/showthrea...cker+bolt+seal
Looks like it might be a common problem.
Old Jan 24, 2007 | 08:14 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
Yea, I'm having a good feeling aobut this...my fingers are crossed for ya
Old Jan 25, 2007 | 10:15 AM
  #27
thunder550's Avatar
Well ****. that didn't fix it. I need to get off my *** and do a compression test. I used Permatex high temp sealant on all the rocker bolts and let them cure overnight before driving. Still smokes this morning.
Old Jan 25, 2007 | 11:29 AM
  #28
Tootall's Avatar
run it around for a little while, or run the crap out of it, there's some probley still in there that hasn't burned off
Old Jan 25, 2007 | 11:35 AM
  #29
thunder550's Avatar
I drove it around this morning and let it get up to temp. Went home and parked int he driveway and left it idling. After about a minute it started smoking again. I'll drive it around some more and run it up and down a few times, but I don't think that's going to fix it.
Old Jan 25, 2007 | 12:32 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
Crap
