PCM swap
Old Sep 30, 2004 | 11:51 PM
OUT2WIN's Avatar
Default PCM swap
joejoe just got done swapping the 5.3 with the 6.0. After putting the 6.0 in with the stock pcm, it seems to be running fine. The question is: If he put in the 6.0 pcm that came with the motor, would it help much? What all is involved in a pcm swap?(plug in and play?)
Old Oct 1, 2004 | 07:45 PM
OUT2WIN's Avatar
Thanx in advance
Old Oct 3, 2004 | 04:06 AM
My PCM had to be moved for the blower install and is now very easy to access. Once you get to the PCM, it is all plug and play in hooking up the new one.
*2002 Black RCSB 4.8L, Procharger P1SC@8lbs. w/3-core, BBK 80mm TB, ASM Headers, 2.5" straight pipes w/2 40 series flows, Westers tune, e-fans, built 4L60E w/transgo, Yank tt converter, Eaton, 4.10 gears, $12K in appearance/stereo junk*
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
Suburbazine
Aug 9, 2015 01:17 AM
bjamick
Aug 5, 2015 10:51 PM
GreyChevy
Jul 7, 2015 08:57 PM
