pcm controlled e-fans?
Old Feb 4, 2005 | 12:40 PM
Default pcm controlled e-fans?
I"m going to get my ls1 fans soon and the nelson harness. I'm going to have the pcm controll the fans, what do i need to tell Westers programming, to turn them on and off at,etc... i will be going with a 160* t-stat also.
thanks guys
Old Feb 4, 2005 | 12:47 PM
SnakeOiler's Avatar
Tell them you will be using the PCM for fan control (that is a setting they will have to turn on). Then give them your on/off temps for the fan.
Old Feb 4, 2005 | 12:59 PM
Just tell them that you want the Pcm to control the fans and that you have a 160T-stat. They will know the temps to turn them on/off at.
Aaron
Old Feb 4, 2005 | 01:03 PM
OLD BULL's Avatar
Default pcm controlled fans
Tell them to edit the following tables. For a 160 thermostat. If you have any more questions or problems let me know I just did this a month or two ago.
System calibration tab(or window)
first stage fan
on 189
off 182
second stage fan
on 189
off 182
electric fan type
(toggle) aux fan
Old Feb 4, 2005 | 01:17 PM
thanks dudes
Old Mar 11, 2005 | 09:29 PM
greentahoe's Avatar
first stage fan
on 189
off 182
second stage fan
on 189
off 182
electric fan type
(toggle) aux fan
Sorry to bring this up from the dead, but Id like to set some LS1 fans to come on with HPTuners. I see the settings mentioned, but what about the
VATS Control
Serial
PWM
None.... is default
Ignition Off
Disable temp ?
Run Time ?
And what about AC settings?
Thanks alot
Old Mar 12, 2005 | 10:48 AM
ttt for ya green!
Old Mar 12, 2005 | 01:14 PM
one03sierra's Avatar
Formerly one92rs
Talking
for the truck there is just a temp setting. 189 on and 182 off. the relays will decide about the a/c controls. three relays>>>>
1 fan on with a/c--temp cool
engine to temp both fans 50%
engine to temp and a/c both fans 100%
Old Mar 13, 2005 | 07:00 PM
what pin does the truck pcm use to controll the fans
Old Mar 13, 2005 | 07:36 PM
OLD BULL's Avatar
Pin #42
http://forum.ls1truck.com/index.php?showtopic=2486
