Patriot Heads
Old Jan 14, 2005 | 10:33 AM
Default Patriot Heads
Anyone using heads from Patriot Performance? Did they give any gains? Which heads should I have them work? 5.3 or LS6? I want the LS6 but I heard I would lose too much compression. Which do you guys recomend?
Old Jan 14, 2005 | 10:39 AM
GEAR M UP's Avatar
I have the Patriot LS6 Stage III with hand porting.
They are working fine for me......
Old Jan 14, 2005 | 02:40 PM
How much more power or performance over stock heads?
I thought LS6 heads caused the 5.3 to lose too much compression with larger combustion chamber. Does anyone know if this is the case?
Old Jan 14, 2005 | 03:30 PM
he has a 427 so it would be a little different then the 5.3. keep the stock 5.3 heads and get them P&P and and I would leave the valves alone. you could also get them milled to increase compression. call patriot and they can help you.
Old Jan 15, 2005 | 12:09 PM
sfj
i say keep the stock 5.3 heads if you are planning on n/a if you are planning FI go with some 5.7 or some 6.0 heads and P and P those and i went ahead and incresed the valve size in the intake side of my heads to a 2.0 and like the results
Old Jan 15, 2005 | 05:05 PM
Good idea on the choice of heads
I think you keep the 5.3 chambers for compression.
Unless your going with a larger bore??
Like one of those 402's I saw advertised on the right.
The mustang boys will be cusin' ya some more
Old Jan 15, 2005 | 05:12 PM
Sport Side's Avatar
No matter who you go with, keep the intake port small & efficient. The stock cylinder head uses a 200cc and flows app. 230cfm @ .600 valve lift. If the 205 afr's were made for a 3.8 bore & a 61cc chamber or smaller We'd be in luck.
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
CashDudeHomie
Aug 3, 2015 10:58 AM
OLD BULL
Aug 1, 2015 05:00 PM
sauldgold
Jul 23, 2015 02:15 PM
