Parish8 xylene?
Old May 28, 2003 | 10:08 PM
Default Parish8 xylene?
Parish8 how are you mixing the xylene in your truck? I'm wanting to try some in my Tahoe it sounds cheaper than 104 unleaded.
Old May 29, 2003 | 12:03 PM
Hit Man X's Avatar
Default Re: Parish8 xylene?
Hey do a search. I posted up some stuff on how to make race gas and such. Use Toulene or Xylene. $2-5/gal the more you buy the cheaper it gets. I explained how to make higher octane, mixing, etc.
It was a reply by me in this forum.
Old May 29, 2003 | 05:17 PM
parish8's Avatar
single digit dreamer
i fill the truck to what i think is about 10 gallons of 92. i put 20 oz of tranny fluid in a 5 gallon gas can, dump about 2 1/2 gallons of xylene in the can and then dump that in my truck, then i take the other 2 1/2 gallons and dump that in the gas can and then into the truck. i drive it for 20minutes or so before i beat on it, give it pleanty of time to mix around.
it has alowed me to go from 6psi up to 9psi with no knock retard. doing a search would get you more info on my experineces with xylene, there was a post in the forced induction section not long ago.
Old May 29, 2003 | 05:18 PM
parish8's Avatar
oh yea, i pay $21 for a 5 gallon can of xylene, that makes a 99.5octane mix come out to something like $2.70/gallon.
Old May 29, 2003 | 06:19 PM
Thanks Parish8 I've got 5 gallons of xylene ready to go in the tank right now.Do you run the mix all the time or just when you're going out to play?
Old May 29, 2003 | 06:45 PM
parish8's Avatar
i set myself up with 15 gallons of mix on friday and when/if it runs out i just go with 92 till the next friday, i usualy end up driving around a day or 2 with 92 and the high boost pully and have to keep my foot out of it then.
WJ MARK
Sep 20, 2010 09:27 PM
DanaliHD
Apr 21, 2005 08:27 PM
SPRAYEDSIERRA
Nov 18, 2003 04:54 PM
parish8
19
Feb 3, 2003 07:42 PM
