Paging BigTex
Old Feb 26, 2005 | 07:37 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default Paging BigTex
Hey Tex,
I've got some electronics hijinx related to the gear selector and my oil pressure gauge. Basically, the trans shifts fine and selects gears fine, but the indicator only reads R and 3rd (mostly R) and the oil pressure is pegged whenever the key is not "off". Now I was thinking that the gauge cluster was messed up, but a cop told me my reverse lights are always on.
Can you look in that magical wiring diagram source you have and help me figure out if the reverse lights are keyed by the PCM or the gauge cluster?
I'm thinking that my gauge cluster may be fried.
Old Feb 26, 2005 | 09:22 AM
BigTex's Avatar
I'll look and get back with you.
The PRND321 transmission selector switch slides over the shifter on the side of the trans. It sends a signal to the electronics as to what gear your transmission has been put in. That part has been notorious for having a bad electrical plug. It commands the cluster lights and probably the reverse lights.
Oil pressure - I'd see if I could manually check pressure. Maybe a scanner or Tech2.
Old Feb 26, 2005 | 08:08 PM
I AM A MOTHERF*CKER
Thanks Richard.
Like the new avatar pic!
Old Feb 26, 2005 | 08:13 PM
gonzo 6.2's Avatar
What was the last thing touched on it before you had problems?Check fuses inside of truck.
Old Feb 27, 2005 | 06:07 PM
I AM A MOTHERF*CKER
I had the tranny out. The guy who reinstalled it tried to adjust the PRND32L selector switch but said it wasn't adjustible. I found out today that I can get it out of reverse by going to 1 and then walking back up to D. I also have more indicators today (nothing changed) -- back to PRND3, still no 2,1 and still goofy (like D will show the R or N depending on what it was in last, unless you go all the way to 1. Starting to sound strangely lke the selector switch is installed wrong or badly.
Old Feb 27, 2005 | 07:25 PM
BigTex's Avatar
Bingo.
Preshr
Sep 6, 2025 09:15 AM
Stainless Works
Oct 8, 2015 12:01 PM
carid
Sep 10, 2015 09:07 AM
