? for pacesetter y-pipe guys
Old May 19, 2006 | 08:14 PM
JT-bo's Avatar
Default ? for pacesetter y-pipe guys
What did you use for a flange on your exhaust pipe to connect to the y-pipe? did you guys make a flange, buy one from a parts store or online, or did you just weld the 2 together? thanks
Old May 19, 2006 | 08:28 PM
1TRUESS's Avatar
I used these - http://www.jegs.com/webapp/wcs/store...tegoryId=11527
Old May 20, 2006 | 12:10 AM
virgils4.85spd's Avatar
Default Mine was...
welded on already and it connected to the factory flange.
Derek
Old May 20, 2006 | 10:23 AM
Okie5.3's Avatar
Originally Posted by 1TRUESS
i used those too, and they worked pretty good but had to notch it for the O2 sensor. now i found a clamp that, IMO, is hands-down the best. its the Accuseal. made by Torca, the same manufacturer as the one above. it is 1.25" wide and like .071" thick, much stronger than the one above.
Old May 20, 2006 | 03:02 PM
1TRUESS's Avatar
Ya, had the same problem with the o2.
Old May 20, 2006 | 03:12 PM
BlackGMC's Avatar
Resident Retard
If you can weld, use something like this.
2.5 inch header flange
3.0 inch header flange
they are only about 5 bucks... Oh and those are the inner diameter measurments... Oh and be kind to my welding job, it's not pretty but it works.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
