pacesetter question
Old Sep 6, 2005 | 02:18 PM
Fogle07's Avatar
Default pacesetter question
got my long tubes in today and they look great but wheres the bolts for them? when i bought my edelbrocks they came with everything but my long tubes didnt? anybody have any idea why i didnt get my hardware?
Old Sep 6, 2005 | 02:39 PM
well my asm's came with new oem gaskets but not bolts. they recommend that you use the factory bolts.
Old Sep 6, 2005 | 02:45 PM
Fogle07's Avatar
what in the world. i got some paper gaskets. i believe factory's are steel or alum. and i got a block off plate for the egr. i just figured they would send some bolts with them though. i guess ill just reuse my ones off the edelbrocks. other than that im 100% satisfied so far.
Old Sep 6, 2005 | 05:52 PM
nightmarechevy's Avatar
I reused the factory gaskets and bolts and no problems so far, only real problem I have had is getting the y pipe to bolt on without leaking.
Old Sep 6, 2005 | 06:48 PM
TurboGibbs's Avatar
I reused the factory bolts as well as the factory gasket and had no problems. I cranked down the clamps on the collector and it sealed up just perfect. The headers were spread farther than the ypipe by about an inch so I just took a ratchet strap and wraped around the collecters and pulled them in.
Old Sep 6, 2005 | 07:28 PM
kerndog5.3's Avatar
I used the stock gaskets and bolts and used the u-bolt clamps for the y-pipe and it all went fine accept i have a little leak where the headers meet the y-pipe but its nothing to cry about
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
andrewlong
Sep 8, 2015 10:25 PM
bisqikss
Sep 8, 2015 03:35 AM
USMCvet0311
Sep 4, 2015 09:43 PM
