Pacesetter ORY with Stainless Works LT's?
Old Nov 20, 2008 | 07:26 PM
RassyMX's Avatar
Default Pacesetter ORY with Stainless Works LT's?
Please excuse my ignorant question but will the Pacesetter catless Y pipe work with my Stainless Works LT's on my 2005 2500HD 6.0 4x4? I have a homemade setup now and its been on there for over a year and is developing leaks and I want to redo the whole exhaust setup.
Y pipe:
http://speed-eng.com/store/pacesette...pe-p-7622.html
My headers:
http://speed-eng.com/store/stainless...0l-p-8626.html
Old Nov 20, 2008 | 08:02 PM
budhayes3's Avatar
PT's Slowest Truck
Well, the SW's have 2.5" collectors, so you'd have to have SW put 3" collectors on there for you since the PaceSetter y is 3", then hopefully they'd slip into the Pacesetter y-pipe. Not sure if the 2 headers come down in the same location or not either. The Pacesetter y-pipe should have some adjustment to it which would help. I don't know of anyone who's tried it. SW offers an off road y-pipe, I know it's more expensive than the PaceSetter ORY, but at least you know it'll work.
Old Nov 20, 2008 | 08:10 PM
RassyMX's Avatar
Stainless Works sells a ORY separately? All i have found is it coming with the headers. Cost isnt really much of an issue just want it to work.
And i am pretty sure my headers have 3" collectors.
Old Nov 21, 2008 | 11:28 AM
budhayes3's Avatar
PT's Slowest Truck
Ahhh, I mis-read your first post, you already have the SW's. Not sure if they sell the ORY separately, but I'm sure they would if you called them. Be sure to mention what size collectors you have, just in case they don't offer an ORY for the larger collectors
Old Nov 21, 2008 | 11:31 AM
GMCtrk's Avatar
I definitely think the Pacesetter ORY will work. Just take it to an exhaust shop and have them fab up some connections. It shouldn't be all that hard I would think. As far as getting an ORY from SW, I've read of some pretty rotten things regarding SW's customer service over on LS1tech.
Old Nov 22, 2008 | 09:17 AM
RassyMX's Avatar
It wouldnt hurt to try the Pacesetter ORy i guess, if i doesnt work out for some reason I can always sell it. I dont think there should be much problems but I just wanted to make sure.
Thanks guys.
Old Nov 22, 2008 | 09:48 AM
dkota1968's Avatar
When i resently put on my AEM/DC sport LT's i bought a pacesetter ORY and it worked with those with some adjustments. I didnt even have to weld anything, just used a few extra clamps. The headers had the old style 3 bolt flange collectors for 2.5 inch exhaust so i got 3in to 2.5 adaptors and used Hooker collector adaptors to slip everything into place and bolt up. I had to extend the cross over pipe a lil bit using a section of slip fit 3 in exhaust you can buy at autozone. You will have to do some tweaking but it will work. I want it to be all clamptogether so I could put resonators in, in case it was too loud which it is with CORSA. Good luck.
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Nov 20, 2015 08:55 AM
Bluchevypick
Aug 18, 2015 09:11 AM
Stainless Works
Aug 7, 2015 10:08 AM
Chiphead
Aug 1, 2015 04:43 PM
