p0120 where do i check? no throttle
hi guys i just finished my 5.3 , jeep wrangler project and i have a p0120 code...the jeep will idle but i have no throttle, i where should i be looking i also have a p2135 code i need help guys
ok guys, i checked the tb, it idles fine.... i mean it moves a bit on initial start......., so im guessing it works, all wires seem to connected and there is a good ground... i cant figure this out.... you think i should get another TB and recheck?
also what is the p2135 code... i thought it was a pedal code?
Did you clean it recently, i.e. remove the blade? If you did, there is a good chance that the blade is ever so slightly off center and dragging on the TB, throwing the codes. Been there.
Greg
Greg
Did you use a used harness? Check the wires going into the throttle body connector very close. You can't tell but the wire might be broken inside the sheilding. Pull on each wire individually and a broken wire will pull apart.
Stainless Works
Apr 10, 2016 04:34 PM
Fast86z
Aug 23, 2015 12:35 AM
bsgiffor
Jul 19, 2015 11:14 AM
GreyChevy
Jul 7, 2015 08:57 PM
