Oxygen sensor help!
Old Feb 16, 2007 | 01:01 PM
BLACKHD01's Avatar
Default Oxygen sensor help!
I put my Pacesetter long tubes on in November 2006. I got a SES light the other day PO134. I check my scan guage and short trim bank 1 and 2 have no reading and the voltage is jumping around from 50-800. So I know that they are not working . My question is will it hurt anything to drive it like this, until I can get some new sensors? Also what would cause them to quit working, I have 68,000 miles on the truck now. Any knowledge on this would be greatly appreciated.
Old Feb 16, 2007 | 01:34 PM
Grumpy5.3's Avatar
ummmm your o2 sensors are supposed to be jumping around
Old Feb 16, 2007 | 01:51 PM
04BlackGmc's Avatar
10 Second Club
yep your front o2's will jump around from 100-900 all the time.unless ur at WOT....
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
Old Feb 16, 2007 | 01:54 PM
BLACKHD01's Avatar
Sorry, i'm kind of a novice wen it comes to these things.
Old Feb 16, 2007 | 01:56 PM
BLACKHD01's Avatar
Does this mean that they are shot or do I need to check my connections, or just get some new ones?
Old Feb 16, 2007 | 01:59 PM
04BlackGmc's Avatar
10 Second Club
make sure you are watching the correct o2's with the scanner if its jumping around then they should be working. do you have them in all the way, tightened. connections good?
Old Feb 16, 2007 | 02:09 PM
BLACKHD01's Avatar
I will check them this evening when I get home, maybe that's the problem sure would be a lot cheaper.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
