overheating?
Old Jul 9, 2006 | 10:31 AM
bomariam1's Avatar
thanks all.
I didn't remove the thermo for daily use (I didn't do it before), it was for testing that the thermo wasn't the cause of high temp.
ok scenarios:
1. the catout after the 2 cat.conveter, and it's just one.
2. I guse this it, I think he reused it because it's steel!.
3. the thermo, will when I toke the car for changing the spark plug they left the car running and the temp gauge was on the red when I get into the car, but according to the dealer engineer that can cause only if it was left for long time, nore over I drove the car for long time.
I forget to tell you that I have removed the pipe from the throttle bady and installed an adapter to connect the 2 pipes (before the throttle and after).
they are installing the head back in the dealer workshop and it will take 3 days, I will update when new info.
Old Jul 9, 2006 | 12:59 PM
If you bypassed the throttle body with coolant hose that is ok but make sure it is connected to the radiator. I am still suspicious about what the dealer mechanic said about overheating, I have left my truck idling for 4+ hrs when hunting (turkey in the spring) and it never overheated.
I would like to talk to that dealer about calling there mechanics, engineers, that is complete disgrace to real engineers.
Old Jul 9, 2006 | 03:26 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Think there's something they're not saying. Doesn't just overheat like that, or burn gaskets to failure... I'm no pro, but something ain't right.
Old Jul 10, 2006 | 12:27 PM
bomariam1's Avatar
sorry for that I was going to say that it was left with temp on the red for long time.
Old Jul 10, 2006 | 12:29 PM
bomariam1's Avatar
you maybe right, but it was my mistake because I toke it to ordinary workshop for spring valve change.
Old Jul 11, 2006 | 02:24 AM
bomariam1's Avatar
latest sad update,
they changed the head gasket and the temp still rising!
what can be the reasone?
can the cam bearing cause this?
Help me to understand
Old Jul 11, 2006 | 04:08 PM
Sport Side's Avatar
Somewhat worried about my truck now... I just did a cam swap and now I have been randomly overheating. Not everytime either. I'm hoping mine is just the thermostat.
Old Jul 12, 2006 | 09:55 AM
bomariam1's Avatar
last and I hope its the final update.
they changed the radiater and it should be fine.
I am typing this reply form the dealer (nice thing), and I am waithing for the car.
Old Jul 13, 2006 | 02:36 PM
bomariam1's Avatar
thanks god,
It's over it was the radiator.
thanks all.
Old Jul 14, 2006 | 08:08 PM
95ImpSS's Avatar
hmm... strange that they didn't flush it as eliminate a possibility... or did they?
