ordering cam this week help me decide?
Old Jan 6, 2014 | 12:42 AM
jmgak47's Avatar
Ahh, I hear ya. I know someone that works there.
Old Jan 6, 2014 | 05:20 PM
bizle's Avatar
I really like the feedback on the comp 265 cam. But was considering having it ground on a 112 for a choppy idle?
Also i seen somewhere on the net that tge high lift verison wasnt recomended for the 5.3?
Old Jan 6, 2014 | 08:56 PM
jmgak47's Avatar
That would be because the chance in the IVC event. The low lift is going to have more low end due to the IVC event being sooner.
I would just go with a custom grind tailored for exactly what your wanting, instead of taking a off the shelf grind specs and changing them for lope. Even if you did want to use the XE high lift lobes I would tight up the split of the cam since you are planning headers in the future, based off how the 5.3L heads flow. If you stick with stock manifolds keep the split to help evacuate the exhaust.
There are better lobe profiles out there now and higher lift will also help your low end out, which your really going to want/need.
Old Jan 6, 2014 | 09:43 PM
bizle's Avatar
What would you recomend? And who do you recomend for custom grinds?
Old Jan 6, 2014 | 11:07 PM
jmgak47's Avatar
Brian Tooley, Patrick G, or Geoff.
You exhaust setup also makes a large difference the the lope you hear, as does tuning, timing and idle speed.
Here is a 215/222 .603/.596 115+3 in my daily LQ9, a very mild mild cam.
Lope...
EPS 215/222 .603/.596 115+3 with stock muffler... - YouTube
No lope... (same cam)
Sleeper... - YouTube
Personally the one I recommended will be pretty darn close to what any of the guys I just mentioned will recommend. With the variation of a slightly wider/tighter split, higher/lower lift, and tighter/wider LSA. But they will all be in the same ball park and perform very close to the same.
Also if you tighten the LSA you will have your HP fall off sooner and less TQ off the stop. A more narrow powerband.
Old Jan 8, 2014 | 11:05 PM
jmgak47's Avatar
This cam in the classified would work well for what your wanting.
https://www.performancetrucks.net/fo...ld-cam-525333/
Old Jan 9, 2014 | 10:57 AM
MPFD's Avatar
11 Second Truck Club
Get a converter first. I don't care what these guys are telling you, camming first especially with out headers a mistake...
Old Jan 9, 2014 | 04:19 PM
jmgak47's Avatar
Yes and no.
He asked what cam to go with and said he may go with headers/stall later...
So that is why he got the answers he did.
Will agree headers are a great supporting mod for a cam and should come first. And if you plan on a larger cam then a converter should come first also or @ the same time as when you install the cam, this is not true if you go with a cam that will work well with as stock converter.
The cams recommended other then the 220/220 will work very well with a stock converter. Some will ague that the 220r is great with a stock converter but unless you roll race that is not the case.
Old Jan 11, 2014 | 07:33 AM
bizle's Avatar
I think im going with the comp 265 low lift 114. From everything ive seen its a proven cam?
What valve spring would you guys run?
And should i buy pushrods?
Old Jan 11, 2014 | 10:19 AM
grey matter 04's Avatar
13 Second Truck Club
Yellow ls6 valve springs
I ran those springs and stock pushrods for 60k miles with my 212/218 low lift cam
Staggered 02
Aug 11, 2015 07:54 AM
dantheman1540
Jul 29, 2015 04:45 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
