opinions on buying a converter..
Originally Posted by BADMOFO
I''d try one first (the converter) and then see if you think you still need the gears, or vice versa.
on the highway you won't see much difference with the stall. going to a 4.10 gear will keep the converter from being under load all the time and give it more life. i see no reason to not go with a 4.10 gear and converter. i wouldn't do them both at the same time though. if you're planning nitrous or a supercharger down the road a 3.73 or 3.90 might be a better choice. if N/A is the choice, 4.10 and the converter will be a very nice combo.
Originally Posted by ridnlow
You mean install them at the same time? They will probably be installed about 2 weeks apart.
Does 250 sound about right to get my converter installed?
i still think 4.10's are too much.
i think it was chingon on here that had yank 3000 and 4.10's and he was very dissatisfied with that combo. the 4.10 was too much and he had vids of him doing burn outs and getting no traction on launching.
i think it was chingon, not sure though.
Im gonna give it a go.. with what i have now and see.. if it is to much then i may have to swap.. hopefully not but well see.. someone told me that my ext cab should do better than a reg cab because of the added weight.. not sure on that..
