ok, no fuel pressure.....
Old Nov 5, 2005 | 07:02 PM
ThunderZ28's Avatar
12 Second Club
Default ok, no fuel pressure.....
seems the fuel pump isnt pumping..
no blown fuses..that I have been able to see
checked the fuel pressure and it is at 0PSI...
so I have narrowed it down, I just need to find out why it isnt working...
Old Nov 5, 2005 | 07:42 PM
litreddevil's Avatar
Banned
CHECK RELAY AND THEN SOMETIMES U CAN SOMETIMES U CAN'T TRY AND UNPLUG THE FUEL PUMP AND USE A TEST LIGHT AND SEE IF YOU R GETTING 12v TO THE PUMP.
Old Nov 5, 2005 | 07:44 PM
jhe2003's Avatar
what about the relay? did you check it? Switch the relays around just in case My .02 cents
Old Nov 5, 2005 | 08:03 PM
ThunderZ28's Avatar
12 Second Club
ok ok guys...
this was a test, and only a test.....
I found the problem......
someone and I am not saying who....
hit the fuel shut off switch and didnt notice it when they did..
then their wife came out, and right then he relized what happened..
now the fuel pump works, but now I have an injector spewing fuel gotta see if I can get it to seat better.. then I can try and start it ..
it's looking better now tho..
Old Nov 5, 2005 | 08:04 PM
ThunderZ28's Avatar
12 Second Club
Thanks Guys for the input
Old Nov 5, 2005 | 08:49 PM
ThunderZ28's Avatar
12 Second Club
allright...
found out why 2 injectors where spewwing fuel..
I found 2 o-ring seals that where torn.
any one know where I can find these????
stealership???
autocrap, and O'rielly's doesnt carry them..
I might be able to special order them from autocrap, but it will be 3-5 days before they would get here.
Old Nov 5, 2005 | 09:44 PM
ap2002's Avatar
try monument chevrolet parts department is open till late....
Old Nov 5, 2005 | 10:00 PM
ThunderZ28's Avatar
12 Second Club
yeah I will most likely go thru them, but they are closed on sat, and sun..
I will check them out on Monday i guess.
so it looks like thunder sits for a few more days.........
Old Nov 5, 2005 | 10:03 PM
ap2002's Avatar
have you called I think when I went it was on a weekend???? but I could be wrong???
Old Nov 6, 2005 | 01:01 AM
Flyer's Avatar
ORiellys should have them ... You just gotta find someone that knows what the hell thier talking about.
It's called an injector oring kit. It's not an ordinary ORing.
