oil starved dmax
Old Mar 16, 2004 | 02:07 PM
first common occurance
call your insurance company right away.
get them involved. - they will start working on your side - they will start calling the shop owner and shop's insurance company.
they will do prob 1 of 2 things
find a used engine with lower miles than your truck has
or put in a new reman or crate motor
even if you have to pay your deductible
the insurance co will subrogate the oil change place and their insurance co - they will also get your deduct back.
highly rec you do this
then get your truck to a gm dealer or qualified dmax repairer
We deal with this on a routine basis.
Old Mar 16, 2004 | 02:56 PM
Flyer's Avatar
I would try and avoid the insurance company. The greedy bastards will prolly try and raise your premiums.
Old Mar 16, 2004 | 04:20 PM
Bad advise and so untrue - One - this is called a "not at fault" accident
so there would be no basis to raise ones rates
This loss would not be his fault.
two - this is why one pays insurance - the insurance company insures
you against this type of risk happening.
This is what you pay for - better use it if you pay for it.
Third - it is the insurance co duty by contract to act on the insureds
interest and protect his property that was damaged.
Old Mar 16, 2004 | 07:57 PM
No way.. They will fight to have their insurance pay but If your insurance company has to pay for it they will raise your rates.
Old Mar 16, 2004 | 08:20 PM
XLR8NSS's Avatar
Adkoonerstrator
Maybe in a perfect world that's all true.
Old Mar 16, 2004 | 08:28 PM
axelhead's Avatar
Once agian thanx for all the support folks however the technical questions still stand. The insurance companies are doing thuer damnedest to not spend money . Little do they know that over the last month of not having this truck they've lost the differance in truck rental and my lost income as this is a plow truck. There is no question of liability nor was there neglegemce on my part you see the truck ran almost steady for four days after the oil change , therefore no slick under the truck and the plug was finger tight so very slow leak so no smoke . It took four days !
What i need to know is if it is rght for them to replace just visibly damaged parts and not the ones that aren't ( visibly damaged that is) . Also the question of the cam bearings being none servicable i.e. how the machine shop is going to " fix them " and of course how did all the push rods get bent when only two connecting rod bearings where spun ?
Old Mar 16, 2004 | 11:49 PM
Flyer's Avatar
I don't think you will find a definant answer to yor internal engine questions. As for the question about is it ok for them to fix only the visibly damaged parts, I'd say no. I would settle for nothing less than a new motor.
If they try and fix that one, it will never be right, and will never get the life it should.
Old Mar 17, 2004 | 08:14 AM
They def have the right to fix the motor vs replacing it.
Per policy they have that right.
Pretty certain that the machine shop will machine new cam bearings - they will either weld them up and machine them down or take oversize bearings and machine them down - will the valve spring tension of your motor and lack up of lube - I am not surprise on the bent pushrods.
Additionally - the oil change shops ins co will owe you for down time - you will need to document loss of income in truck rental and plowing
Old Mar 17, 2004 | 08:15 AM
Too bad you dont work in the insurance industry.........
Old Mar 17, 2004 | 08:17 AM
Again - too bad you dont work in the insurance industry and understand policy and fair claims acts........
