Oil PUMPS
Old Sep 27, 2009 | 12:27 AM
GMCtrk's Avatar
Originally Posted by GMCtrk
I couldn't give you an exact answer, but more is generally not better. The more oil you got in there the more resistance to flow, may cause some sort of failure of the pump. I'm just boggled at how everyone thinks they need a "high flow" oil pump and LS2 timing chains and all this other BS. I suppose everyone just follows whatever some "guru" says like puppets.
meltdown.
Old Sep 27, 2009 | 09:38 AM
budhayes3's Avatar
PT's Slowest Truck
That's 1 quart too much. The Gen III's take 6 quarts with filter.
Mine holds a little over 6, but I use a longer filter, about the length of the old PF-59.
I'm not sure how much volume my stock pump puts out, but oil pressure has never been a problem for me, not sure what the factory gauge numbers figure out to in reality, but my gauge always pegs at WOT, and is over 40 psi at idle with either Mobil1 or Amsoil 5w-30. Too much pressure can blow seals out and may cause blowby into the combustion chambers...although I'd think/assume/hope that a GM factory part wouldn't have that problem, especially since it's a production part.
If you're only a quart over-filled you should be OK, but too much oil can definitely cause problems. The oil can foam and lose it's ability to lubricate, as well as find it's way into the intake through the PCV system, which is already a problem with the GENIII engines with the oil at the correct level.
Hope the new oil pump works out for you Jermoslin, good luck with your set up
Old Sep 27, 2009 | 08:58 PM
Jermoslin's Avatar
If you have had your oil pan off before You will see the full mark on the dipstick is about 1" below the windish tray. Seven quarts don't even fill the pan up completely. the pump I used it for the NNBS with displacement on demand. Yes, LS1, LS6, 4.8, 5.3, 6.0 are the same pumps and you can only buy an LS2 chains all new GM LS motors chains use the new bigger chain.
Old Sep 27, 2009 | 09:04 PM
budhayes3's Avatar
PT's Slowest Truck
"windage" tray
...the oil pan isn't supposed to be completely filled btw...
Old Sep 27, 2009 | 09:05 PM
GMCtrk's Avatar
The dipstick isn't an accurate measurment. GM says 6 quarts, so that's what it is. But what would they know.
Old Dec 31, 2009 | 12:12 AM
lucky77's Avatar
Banned
can any- comfirm what oil pump NNBS come out with..
im getting two different part #'s ( #12612289) & ( #12626407) . ..
Old Jan 1, 2010 | 01:10 PM
bohr898's Avatar
Restricted User
Part Number: 12612289 List Price Core Price Your Price
Engine - Lubrication - Oil pump Oil pump, hummer h2 - 6.0l, 6.2l 2008 - 2009
$110.84 $0.00 $82.13
Part Number: 12626407 List Price Core Price Your Price
Engine - Engine parts - Tensioner Tensioner - 5.3 liter 2009
$38.88 $0.00 $28.81
looks like the 1262 is for the 5.3 andd at that price i just couldnt say no
Old Jan 1, 2010 | 04:34 PM
lucky77's Avatar
Banned
$38.88 $0.00 $28.81
thanks bro.. i put the wrong part# on the second columm. . but got all my info straight.. im gonna be running high volume pump ( #12612289) alot of people are running it.. / i dont think my oil pan will strave oil,
Old Jan 1, 2010 | 04:48 PM
f4tal's Avatar
let us know how it does...
pupi305
Sep 14, 2015 11:40 AM
Tigger Welder
Sep 2, 2015 08:17 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
