oil pump and timing chain upgrade, suggestions....
planning on doing the cam swap this coming weekend. i think i am going to go ahead and replace the timing chain and the oil pump.
ok, what chain and pump to get? i want a bolt in deal, no modifying this or that to make **** fit.
seems like i remember someone mentioning the LS6 oil pump from a Z06 vette, will that work and is it a better piece?
ill be getting all the valvetrain from Comp...might just get their timing set.
would like to get the parts ordered tomorrow, thanks fellas. CHIP
whats an LS6 pump gonna cost me from the dealership? im assuming thats the only place i can get one?
if i get the LS2 chain, do they use the same gears?
its usually the chain that stretches giving you the slack and the gears are normally fine. im thinking just change the chain itself.
has anyone reused their original crankshaft bolt?? isnt it a torque to yield bolt? CHIP
Correct me if I'm wrong but I have never recalled anyone breaking a timing chain so why not use the stock one? The crank bolt should be replaced cause it is torque to yield, however keep the stock one to draw the pulley on to the crank, then put the new one in and torque it.
The stock chain has been known to hold a good amount of power, yes. But if your doing a cam swap and find your chain to have some slack, go ahead and replace it now. Like mentioned above. Shoot for an LS2 chain and an LS6 oil pump. Id hit up Scoggin Dickey for both. Chain was $28 and the pump was $75.
12586482 - LS2 chain
12586665 - LS6 pump
A little pic if you guys havent seen this.
12586665 - LS6 pump
12586665 - LS6 pump
12586665 - LS6 pump
ordered the LS2 chain, new crank bolt, and LS6 pump from Scoggin Dickey today. along w/ the cam, pushrods, springs, retainers, and locks from Comp Cams. should be here by this weekend so i can do the swap. already got all the gaskets and a new water pump. ordered the spring compressor from MORE Performance too. i've got my work cut out for me this weekend!
now ive got to get on the phone w/ Wait4me for a computer. CHIP
