Oil pump pickup tube and o-ring questions
Old Mar 18, 2014 | 09:56 AM
Robert91RS's Avatar
Originally Posted by Atomic
You need to match the oring to the TUBE not the pump.
^This
Per GM:
12557752 Blue- used on oil pickups WITHOUT locating groove in tube
12584922 Orange- used on oil pickups WITH locating groove in tube
The LS6 and LQ4 use the same oil pump
Old Mar 18, 2014 | 09:57 AM
aldrichg9's Avatar
Thanks atomic and robert
I am going to buy an orange o-ring which I think is what I already have.
Old Jun 15, 2014 | 10:24 AM
any update on this? I have the same problem.
Old Jun 15, 2014 | 10:34 AM
aldrichg9's Avatar
Ya
Go with the orange oring.
Old Jun 15, 2014 | 11:02 AM
Is it more of an orange or a red. I have a blue one and a red one. what year is the orange one for? My donor block was a 2003 6.0. And a Katech LS6 pump with tube from the donor.
Old Jun 15, 2014 | 11:19 AM
GMCtrk's Avatar
The o-ring will be specific to the truck pickup tube, as Atomic already explained.
The factory O-ring on my 02 LQ9 was GREEN, however, the replacement from GM was orange/red. The blue one is for the car engines I believe.
Old Jun 15, 2014 | 11:59 AM
aldrichg9's Avatar
As far as I know there is only two.
Blue or red/orange
I think the red turns orange after a while
Old Jun 16, 2014 | 12:27 AM
I got mine fixed. The o ring that I took off was orange and lose fitting. I replaced it with the red and is all good now. I had the green, black, orange, blue, and red just to finally fix this annoying valve train noise and low oil pressure. The green fit tight but fit the tube lose, the black was wobbly but fit the tube, the blue fit the tube but was lose and wobbly, the orange fit the tube really well be didn't seem to seal in the pump. I tried the red last and it fit perfect on the tube and in the pump. Nice seal so I went with the red. I got it all put back together and the engine sounds great and my oil pressure at idle is 50-55 psi..
Old Jun 16, 2014 | 05:30 AM
RezinTexas's Avatar
this came with my Melling pump
The_W
Oct 28, 2015 09:00 PM
Bluchevypick
Aug 18, 2015 09:11 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
