Oil pump
Old Jul 30, 2013 | 04:50 PM
JDC's Avatar
JDC
Default Oil pump
Can you get at the pressure relief valve in the pump by just dropping the pan?
Old Jul 31, 2013 | 12:14 PM
03klugss's Avatar
The oil pumps on these are pretty easy to remove. If you are going to have the pan dropped anyways especially you could just pull the pump assembly off and get right at the pressure relief valve.
Actually the oil pump can be removed without dropping the oil pan at all, it's not fun but it can be done. Did an oil pump swap just a couple months ago myself and didn't loosen any bolts at all on the pan. Doing it this way you will definitely get frustrated though but just saying it can be done.
Old Jul 31, 2013 | 12:31 PM
JDC's Avatar
JDC
Yea I've lost one in the pan before lucky the alum. pan makes for easy magnet searching. But I wanted to check if the relief valve is stuck before I pull the frt apart. Its a new motor and when the oil pressure finally came up it pegged the gauge and then dropped low and after that there was no pressure. I pulled the filter and up plugged the coils and then cranked it and nothing came out so i'm pulling the pan to check the valve.
Old Jul 31, 2013 | 03:00 PM
03klugss's Avatar
Ah I see what you're saying. Yeah their have been issues unfortunately where their can be a burr in there where the relief valve is and they get hung up.
Old Jul 31, 2013 | 07:17 PM
JDC's Avatar
JDC
Frt cover has to come off.
pupi305
Sep 14, 2015 11:40 AM
Tigger Welder
Sep 2, 2015 08:17 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
