oil pressure sensor?
this is about an 88' small block carburated 350.
i'm leaking oil from the block where the oil pressure sensor is.
the sensor is horizontal with an elbow connecting to a shaft that is going into the block. the shaft is loose and i can turn it, but can't get it out because the sensor is still connected to it.
I DON'T KNOW WHICH WAY TO TURN THE NUT ON THE SENSOR
i'm thinking about maybe using so penetrating oil on the nut?
and some teflon tape around the threads of the shaft that goes into the block?
but i'm not sure if the tape can handle that amount of heat, what do you think?
sorry i can't post a pic
i figured out which way to turn the nut, but now i only need to know what i should use to make sure that shaft stays put in the block. any ideas?
sorry for not introducing myself. my name is matt and the truck is an 84 silverado with an 88 block, edelbrock intake and carb. trans is a 4spd with granny low! will post pics once i figure it out.
superchomper2003
Aug 26, 2015 09:39 AM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
