Oil pressure issue
Old May 8, 2015 | 07:32 PM
david0982's Avatar
Default Oil pressure issue
So I recently swapped out engines in my 2003 silverado with a 2005 5.3 had a 5.3 before but lifters went our so decided to upgrade while I was at it. Anyway when I first fired the engine my oil pressure gauge wouldn't work just stayed at 0 so I took my turbo feed line off and manually checked it and it had 30psi at idle. Anyway I figured it was my sending unit so I replaced it and my electronic gauge worked fine for a few days and yesterday it stopped working again. Anybody have any ideas?
Old May 8, 2015 | 09:33 PM
01silvy's Avatar
I would double check all the grounds since you did swap the engine. You could also have a short in the wiring to the oil pressure sender.
Old May 9, 2015 | 10:36 AM
david0982's Avatar
Yea I'll double check all my grounds but I would think that Id be having some other issues if it was a ground.
Noah Burns
Sep 7, 2015 05:50 PM
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
