Oil pressure?
Old Nov 12, 2013 | 11:14 AM
Go5.3tt06's Avatar
Default Oil pressure?
2006 Silverado 170,000 5.3 I didn't reliazed my oil gauge at 40 psi didn't go 60/80 psi when you full throttle in drive. Any idea cause. I check oil level good. Oil sensor bad?
Old Nov 12, 2013 | 06:16 PM
black00chev's Avatar
Slowest turbo build ever!
cant really tell what your asking... but before I had the cam swap done on my truck, it would be 60-65psi cold, then come down to about 50-55psi warm idle, then usually 60psi while driving and around 65-70psi when WOT.
Since the cam swap with new oil pump, cold or warm idle is 35-45psi, about 50psi driving, and goes up to about 65psi WOT.
Old Nov 14, 2013 | 05:29 AM
Go5.3tt06's Avatar
It may ckuster went bad? Other day. My oil pressure finally show read correctly always 50-60 psi drive 60+ mph. Floor it 80 psi. Or my oil is to thin since I run 5w30 sythenic royal purple. Outside is about 25 degree cold is normal for oil pressure been stay 40-45 floor it 45 psi that it. When it get hot would show oil more pressure. I not sure if it's normal. Or just bad cluster or oil pressure sender
Old Nov 14, 2013 | 06:08 AM
gmstrong's Avatar
your oil pressure is fine.
Old Nov 14, 2013 | 08:22 PM
Go5.3tt06's Avatar
It work fine. Guess it is just to cold outside since my oil is sythenic 5w-30 would be make sense?
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
