Oil level dummy light
Old Sep 2, 2008 | 11:41 AM
brent5631's Avatar
Default Oil level dummy light
i think that my oil level gauge that is the pan is stopped working. my truck is a stock 99 with a 5.3. i have never had any problems with it burning a lot of oil or anything like that and even recently it hasn't been leaving any spots anywhere. so the problem is that last night i got in it and the check oil level light was on. which is weird cause it has never come on before. so i check the oil and its low. so today i filled it back up and the light is still staying on.
so what i am wondering is has anyone else had their oil level gauge go out and is there anyway to make sure it is the gauge that is wrong? like a way to test it?
Old Sep 2, 2008 | 11:45 AM
thunder550's Avatar
High on diesel fumes
The only way that I could think to test it would be to pull it out of the pan and move the float with it plugged in to see if it registers the change on the DIC.
Old Sep 2, 2008 | 12:09 PM
kbracing96's Avatar
It's probable just stuck, If you know it has oil, just drive it around for a while, take it off some sweet jumps, and see if it doesn't go out.
Old Sep 2, 2008 | 12:18 PM
thunder550's Avatar
Need video when you do this!
Old Sep 2, 2008 | 03:17 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
lol best recommendation ever,
you should leave a disclaimmer at the bottom of your posts
"I hereby take no responsiblity for anything I might have said when sober or under the influence, or anything I may or may not have implied. You taking my advice you do so upon your own risk and you are liable to damaged property and more then likely death as the result of my advice"
Corvette454l88
Sep 1, 2016 01:24 AM
Bluchevypick
Aug 18, 2015 09:11 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
Ferocity02
Jul 17, 2015 07:05 PM
