Oil Filter Relocation?
Old Mar 12, 2003 | 09:45 PM
KeukaZ71's Avatar
Default Re: Oil Filter Relocation?
rob, do you have ramps or a steep incline? i found this works the best to prevent the mess. i used to do the oil change on a semi level surface and had the same problems with the Z71. i changed mine for the 1st time on ramps a few weeks ago and didn't noticed any mess. plus you get more of the oil out i think. doesn't work so good on my mom's intrigue. the drain plug is in the front. anyone ever tried changing the oil on an olds intrigue? it sucks, especially w/o ramps or a lift. the filter is different. it is like an insert. hard to find anywhere. had to go to a GM dealer at first, then i bought out autozone when i found out they had STP fitlers for the olds for $2.99. the filter is flush with the oil pan so it is hard to get an oil wrench on that bitch
Old Mar 13, 2003 | 12:37 AM
Default Oil Filter Relocation?
Has anyone done this yet? If so, where did you put it? and where do I get a kit?
My '95 Jimmy had the filter mounted horizontally, and that was great! Alot less mess that way. Just wondering if it was possible to do that on these trucks. Especially 4x4's, when I change the oil now, it drips right on top of one of the skid plates, not to mention all down my arm. <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" />
Old Mar 13, 2003 | 08:21 AM
I usually jack the front end up a little, which helps with the oil coming out of the plug, but when I change the filter... it still makes a mess!
Old Mar 15, 2003 | 02:49 PM
That's a good idea I guess. I think I may have to look into this situation. If I come up with anything, I'll post it.
REDCYCLE13
Sep 15, 2016 03:02 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
97_ek
Sep 23, 2015 09:16 PM
cousblake11
Sep 9, 2015 06:52 PM
