Oil Cooler?
When I boosted my 13' silverado, I used the block that feeds the oil cooler to feed my turbo. I'm thinking not having an oil cooler is likely leading to hotter oil temps, although I haven't confirmed this yet. I'm looking at getting one of those blocks that has two connections so that I can feed both the turbo and the cooler. My question is, would you guys use the stock cooler that is built into the radiator or get an aftermarket one?
Mine own preference would be to use the radiator's oil cooler. The next consideration is whether you want to feed the turbocharger hot engine oil or cooled engine oil, I forget how it was arranged on the Buick V6s but whichever it was, that is what I would emulate.
Originally Posted by swathdiver
(Post 5422234)
What makes you think your oil temps are high? You getting lower oil pressure at idle, after driving it for a bit?
Originally Posted by B00sted2007
(Post 5422314)
Turbos dump a shit ton of heat into the oil, I know mine was 250+ in just a few minutes putting around the block not being hard on it. I added a B&M generic 5x10 cooler and it kept it in the 200-220 range.
Originally Posted by Atomic
(Post 5422397)
(Post 5422397)
No I added it with one of those billet block off plates. Also had ports for temp sensor and turbo feed.
https://i11.photobucket.com/albums/a...ps6f240d10.jpg |
(Post 5422412)
