oil consumption and catch can alternatives
Old Jul 31, 2005 | 04:58 PM
02sierraz71_5.3's Avatar
Default oil consumption and catch can alternatives
Anyone actually put a real pcv valve in instead of using a catch can. Im getting alot of oil consumption when going wot Im almost positive its getting sucked into the intake.
Old Jul 31, 2005 | 06:16 PM
99Silver6.0's Avatar
Convert to the LS6 valley cover. That will help big time. It works, it worked on my 5.3! Cheap and really easy to do. Crank case air is drawn from the valley of the engine where the chance of oil being caught is alot less. Versus the air being pulled from the valve cover where most know that alot of oil goes through with the air. Most people dont understand that the LS6 valley cover is about the best choice when it comes to the oil problem. Like on GM-Fullsize.com, numerous people bitch about how much oil is being used between oil changes. And how their rigged up wal-mart catch can doesnt work. I mention the LS6 cover time and time again and they just say "well, im gonna re-rig this catch can. I THINK its gonna work."
Heres the difference between the valley covers. Black box is the baffle from which crank case air is pulled.
Old Jul 31, 2005 | 11:56 PM
thats good to know but I really dont want to take the majority of the top half of the motor off just to fix this. I do have that gasket though if anyone wants it. Have you ever heard of anyone just putting a regualar ball type pcv valve in there
why didnt gm do it?
Old Aug 1, 2005 | 06:31 AM
budhayes3's Avatar
PT's Slowest Truck
why didnt gm do it?
The fixed orifice style PCV was designed since GM originally found the problem on engines with the traditional style PCV...my truck came with the old style PCV from the factory. The fixed orifice PCV is supposed to help fight oil consumption (as we all know, it doesn't work)
Old Aug 3, 2005 | 05:36 PM
I bought a regualr ball type pcv and we'll see what happens. After a long drive I looked at the stock one and it was all junked up you could tell it had sucked in oil and gummed up part of the hole.
Old Aug 3, 2005 | 11:25 PM
white1's Avatar
Ok. This site is great. Just about one minuite ago I learned what a catch can was. Then I made a post abot loosing a quart of oi; within 2000 miles, then I read this thread, and remember changing my PCV valve. Damn, should have kept the old one. Anyway, it looked the same as every PCV valve I've ever seen defore, I guess its the ball type youre talking about. What else should I try??
Old Aug 4, 2005 | 12:05 AM
evidently they had complaints about oil consumption with the old ball style pcv so they went to the newer style and ended up changing back. This was just something cheap Im trying before I put in a catch can Im just too lazy to replace the valley cover. If anthing I would rig a shielding piece inside the valve cover
Old Aug 4, 2005 | 06:46 AM
BLACKHD01's Avatar
How much does it cost, and what all is involved in swapping them out, sorry not to mechanicly inclined.
Thanks,
Jason
Old Aug 4, 2005 | 07:42 AM
OBXMarine's Avatar
Thanks,
Jason
LS1 to LS6 PCV conversion
Old Aug 4, 2005 | 09:03 AM
budhayes3's Avatar
PT's Slowest Truck
You can tell the difference between the 2 PCV valves by shaking them...the ball style will rattle. The fixed orifice PCV is basically a PCV valve shell with a tiny hole at the bottom...there's nothing inside it.
