Oh No, what went wrong
Old Oct 3, 2009 | 04:57 PM
Oldcrow's Avatar
Default Oh No, what went wrong
Returning from a fishing trip the other day I pulled the boat back 200 miles and the 05 6.0L ran fine. The boat pulled a little harder than I thought it should but there was a very strong cross wind.
When I got home I backed the boat in the garage, everything was fine.
After a while I went up to the store (just a few blocks) but the truck sputtered like it was nearly out of gas. Got it home and parked it in the garage.
This morning I went out to start it up and it was hard to start and would not run.
If it did start it quit right away and once coughed up(backfire pop) a bunch of wet sooty substance all over the wall and now the garage is full of smoke
Thought maybe a bad fuel pump, I have 78,000 on the rig. But when I turn the key to the run position I can here the fuel pump run then stop.
I can hear it again after an attempt to start
Old Oct 3, 2009 | 05:02 PM
Spoolin's Avatar
GFYS and STFU
What color is the smoke? Black or white? You have a check engine light on?
Old Oct 3, 2009 | 05:08 PM
dirt track racer 81's Avatar
possibly could be your fpr
Old Oct 3, 2009 | 05:09 PM
Oldcrow's Avatar
Blue tint.
I had a check engine light but erased it, it was about cat performance.
I have a set of LT headers and have not turned off the rear O2 sensors.
Old Oct 3, 2009 | 05:11 PM
Oldcrow's Avatar
Where is the fpr?
the o2s wont be your problem. is your truck an 05 or just the motor an 05
Old Oct 3, 2009 | 05:19 PM
Oldcrow's Avatar
05 Suburban 2500
Old Oct 3, 2009 | 07:31 PM
03 BLACKOUTSSS's Avatar
blue smoke = oil in the fuel? PCV issues?
Old Oct 3, 2009 | 07:44 PM
dlt76028's Avatar
mine did that when i had bad 02's
Old Oct 11, 2009 | 11:04 AM
65SSZO6's Avatar
Have you got the truck started yet?If not have a friend crank the engine over as you hit the bottom of the gas tank with a plastic or rubber mallet.If it starts you need a fuel pump.Clean or replace your PCV valve also.Good luck
