Oh my, I think I've made a mistake >.>
Old Aug 13, 2010 | 11:48 AM
meangreenburban's Avatar
Originally Posted by 1dirtybird
Did you pull the heads? On vortec heads you have to cut the guides to have anything over .460 lift. Also your press-in studs arnt going to like the pressure from those 918's. You dont have to cut the seats for the 918's but you will kill your seals in no time at all.
As for push rods stockers will work fine as long as you are not using guide plates. A cheap fix are 92-95 stock LT1 push rods as they are hardened.
Alright cool I'm not running guide plates so that'll be alright. As for the seals, are you saying the 918s will move the studs around and compromise the seals quicker? Is there anything I can do to prevent it?
And thanks for the feedback from everyone, it's greatly appreciated
Old Aug 13, 2010 | 12:03 PM
1dirtybird's Avatar
No the guide bosses stick up too far, and need to be machined down on the L31 heads. The bottoms of the retainers will hit the seals. if i remember right with a 1.5 rocker that cam runs .49X .51X on lift. Its been a while but i ran it in one of my LT1 cars and loved it. One casting is worse then the other. I have a set of 906's and they had to take off a quite a bit to clear .500.
Vortec350ss
Jan 12, 2016 10:36 PM
Chewy07
Nov 14, 2015 09:46 PM
Velocity1
Oct 2, 2015 08:01 AM
The_W
Oct 1, 2015 02:35 PM
