Which Off-Road Y pipe??
Old Dec 21, 2005 | 02:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The pacesetter y-pipe wil NOT bolt up. I have one and Im going to modify it to work with my dynatechs. The pacesetter y-pipe has slip fit ends that will havelem. With to be cut and at an angle with flanges welded on them and also cut to the correct length so that the flange at the end of the y-pipe will meet up with the exhaust. You are a 6L guy so you dont have that last problem. With a y-pipe and an aerochamber I think it would sound pretty good. And yes pacesetter sells just the y.
Old Dec 21, 2005 | 03:40 PM
Yeah im thinking about just doing that or getting a custom setup built from the y back!! Im going to check on the pacesetter setup tonight and call a few places to see what they will charge to build a custom Y or X pipe setup!! Thanks for all the responses and I will post up what I decide to go with.
Old Dec 21, 2005 | 07:46 PM
greentahoe's Avatar
Im glad to see that you kept the truck! On the issue of your exhaust, youre in Texas! Im sure there are a ton of shops that could use a magnaflow X and cut and weld some mandrel bends to get everything to meet up. Sent you a PM!
carid
Oct 28, 2015 08:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
carid
Oct 1, 2015 09:22 AM
