OEM head bolt part number needed
Old Oct 30, 2009 | 04:58 PM
JustBlazin's Avatar
Default OEM head bolt part number needed
Anyone have the OEM part number for the Head Bolts for a 2004 GMC denali. I just need one side, the Dumb people at the dealership didnt know.
Thanks
Old Oct 30, 2009 | 05:11 PM
06WT's Avatar
longer bolts 11519772
shorter bolts 12558840
or head bolt kit 17800568
you will need 8 long ones and 2 short ones
had to edit for ya thoose were old #s
Old Oct 30, 2009 | 06:22 PM
06WT's Avatar
changed above as well
and you can re-use the 10mm head bolts the ones closest to the intake but not recomended
Old Oct 31, 2009 | 09:42 AM
budhayes3's Avatar
PT's Slowest Truck
On an 04 all of the bolts should be the same size, as GM machined the holes in the block deeper since techs were putting the long bolts in the short holes and creating problems...
Old Nov 1, 2009 | 07:42 AM
06WT's Avatar
yeah i wasent sure wen they changed the block design. i know my 06 block they are all the same.
Old Jan 24, 2013 | 12:52 PM
Yohns Kustom Fab's Avatar
Formerly classic_speed (2015-06-02)
Is the difference in the bolts in the heads or the block? Im putting 241s from an 02 on my 05 lq9 block...
Old Jan 24, 2013 | 02:05 PM
Robert91RS's Avatar
Difference is in the block.
Old Jan 24, 2013 | 03:20 PM
Ferocity02's Avatar
I used Felpro head bolts, I think each set was around $16 for my engine.
Three6GMC
Nov 5, 2015 10:02 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Aboss
Jul 9, 2015 10:28 AM
6.Slow06
Jul 7, 2015 09:19 PM
Mzay
Jul 6, 2015 11:05 PM
