OEM exhaust manifold ?
Old Jan 27, 2013 | 02:36 PM
snowshoejeep's Avatar
Question OEM exhaust manifold ?
I am working on an engine swap using an 06 5.3 LM7 and the stock enhaust header is hiting the frame rail...
Some where I read about using camero/firebird headers to get more clearence...
Can some one tell me what years the camero/firebird headers would fit my 06 LM7 (5.3)
Thanks to all....
Old Jan 28, 2013 | 01:09 PM
Question
bumpity bump
Old Jan 30, 2013 | 02:09 PM
Question
Old Jan 31, 2013 | 11:32 AM
Exclamation
Old Jan 31, 2013 | 11:42 AM
low2001gmc's Avatar
you probably aint getting a response due to folks wondering what swap is in or not knowing what would clear on a jeep, assuming swap is in a jeep....
Old Jan 31, 2013 | 07:01 PM
99-02 f-body manifolds are all the same design no difference in exit locations or cat locations. 98 was a bastard year and had a set of stainless steel dual wall manifolds that exit in the exact same spot but can be cut and welded to fit as you need for your build.
Old Feb 1, 2013 | 01:01 PM
Exclamation
Thanks tamu...
Are the 99-02 f body manifolds for the 5.7 and or 5.3?
I think they are the ones that tuck in a little closer to the block. right?
The problem I have with the stock Y pipe is the drivers side kicks out wider with the stock 06 5.3 exhaust header so that set up doesn't clear my 79 Jeep Cherokee frame.
Rick
Old Feb 3, 2013 | 09:34 AM
Exclamation
Dan Neumann
11
Aug 7, 2022 09:06 AM
jfuegner
Dec 22, 2016 03:47 PM
Stainless Works
Apr 10, 2016 04:34 PM
maxspeed05V
Aug 17, 2015 08:41 PM
Stainless Works
Aug 4, 2015 12:56 PM
