odd idle
Old Jan 5, 2009 | 08:39 PM
02SilveradoLT's Avatar
Default odd idle
Well it's been really cold here lately, and I'm not sure if that has anything to do with it or not. But anyways when I first start up my truck the idle will go way up to 2000rpms which should be normal in the cold I think.... But then it goes way down like to 500rpms and it gets rough and adventually will die unless I give it some gas... However when I do give it some gas it seems like I can't give it just a little bit I have to push and push and push a little more then the rpms will jump up to 2000 again all of a sudden then go way back down..... It will do this for a couple minutes till the engine gets a little warm
Old Jan 5, 2009 | 08:48 PM
Dirty Dave's Avatar
You're intake gaskets may be leaking. If you're ses light comes on with codes p0174 and p0171 you'll need to replace them.
Old Jan 5, 2009 | 09:01 PM
02slow4.8's Avatar
my truck did the same thing.... it still does but not bad at all. I cleaned my Idle Air Control Valve and it helped my cold idle incredibally. My truckwould die like yours, now it will hold an idle at 1k when its cold. It is located on the throttle body, drivers side. There will be 2 sensors. It is the top one. I took the sensor out, cleaned it off with some throttle body cleaner, cleaned my throttle body a bit, and started it back up.
Old Jan 5, 2009 | 10:14 PM
the ses light came on so I will check the codes tommarow and see whats up. Thanks for the replys guys, and I will post up my codes tommarow. Its just so weird that after about a minute or two it will idle just fine......
Old Jan 6, 2009 | 03:58 PM
Well I went down the local autoparts store to use one of there diagnostics tools, and on the way there the ses light turned off so who knows for now.....
Old Jan 6, 2009 | 08:26 PM
Fireman31's Avatar
clean your MAF, TB, and IAC........
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
