odd idle
Well it's been really cold here lately, and I'm not sure if that has anything to do with it or not. But anyways when I first start up my truck the idle will go way up to 2000rpms which should be normal in the cold I think.... But then it goes way down like to 500rpms and it gets rough and adventually will die unless I give it some gas... However when I do give it some gas it seems like I can't give it just a little bit I have to push and push and push a little more then the rpms will jump up to 2000 again all of a sudden then go way back down..... It will do this for a couple minutes till the engine gets a little warm
my truck did the same thing.... it still does but not bad at all. I cleaned my Idle Air Control Valve and it helped my cold idle incredibally. My truckwould die like yours, now it will hold an idle at 1k when its cold. It is located on the throttle body, drivers side. There will be 2 sensors. It is the top one. I took the sensor out, cleaned it off with some throttle body cleaner, cleaned my throttle body a bit, and started it back up.
the ses light came on so I will check the codes tommarow and see whats up. Thanks for the replys guys, and I will post up my codes tommarow. Its just so weird that after about a minute or two it will idle just fine......
